Flash Failure In Calculation In Heat Exchanger Hysys
#1 AHMEDENAS3385
AHMEDENAS3385
Posted 25 June 2021 - 05:52 PM
WHY THE HEAT EXCHANGER SIMULATION APPEAR FLASH FAILURE CALCULATION WHEN I PUT THE SHELL SIDE PARAMETER (H2O) INLET temperature 42 and 80 and tube side gas (co2) inlet temp. 97 and calculate out let appear flash failure calculation...where the problem plz
  • 1,657 posts
Posted 25 June 2021 - 06:07 PM
By setting the water side temperature difference and flow rate, you are also fixing a duty for the exchanger. I suspect when you apply that duty to the gas side, the resulting gas condition would be unrealistic. The simulation cannot supply a converged answer for the conditions you supplied.
