Backpressure Control Valve Low Flow
Started by james.corrobro@gmail.com, Jun 27 2021 12:54 PM
Posted 27 June 2021 - 12:54 PM
I have a backpressure control valve to maintain 100.psig on a separator
The normal flow is 10 mmscfd , max 12 mmscfd and min 2 mmscfd
However there is a case where I see 0.5 mmscfd flow
Should the Control Valve be sized for the range of 0.5 to 12 mmscfd ??
Posted 27 June 2021 - 04:24 PM
Is this valve already in service?
Posted 28 June 2021 - 02:12 AM
Then the minimum flow is 0.5 mmscfd and yes, the control valve should be sized for 0.5 to 12 mmscfd...
Two Phase Reverse Flow -Psv Sizing For Check Valve Failure CaseStarted by Guest_namita.modak1_* , Yesterday, 08:15 AM |
Flow Through A Perforated PlateStarted by Guest_Ahmadhamzahperta_* , 13 Feb 2026 |
Gas-Liquid Pipe Flow Friction Loss CorrectionStarted by Guest_Huba_* , 18 Dec 2025 |
Software For Calculating Flow Through A PipeStarted by Guest_Deep24_* , 07 May 2018 |
