Cryogenic Refrigeration System - Vle Deviation
Started by cat, Jul 04 2021 08:38 AM
Posted 04 July 2021 - 08:38 AM
What could cause the accumulator (flash drum) to deviate from VLE?
Design is a typical cryogenic system. This is a c3 ref system for ethylene. We have an accumulator, downstream of it is JT valve that feeds to a kettle type heat exchanger. This heat ex interchanges with a ethylene (a separate c2 BOG system) and the vapor being generated is fed to c3 BOG compressor. The discharge of the BOG compressor goes to a condenser with CW and goes back to the accumulator.
We are topping up propylene to the accumulator manually.
The incident time, we topped up c3. It was observed that the accumulator temperature dropped significantly. There was still liquid during that time. Closed everything and let the temp and pressure rise. However, temp increased to ambient but pressure (500 kpag) was seen not to be equal to VLE which is supposedly ~1200 kpag and was found to be decreasing. All transmitters are good and validated by local gauges. An attempt to open the vent on top of accumulator led to dropping temperature to zero.
The system was just commissioned and all parameters were running smoothly for three days already. We needed to stop as the external ethylene loop with cryogenic tank is at low pressure already. This event happened on restart.
Can nitrogen be a culprit?
Posted 04 July 2021 - 09:36 AM
A picture is worth a thousand words. It's impossible for us to troubleshoot with such little information. All you will get without lots of data are guesses. Not a good method for efficient problem solving. First, you should tabulate the data, including design values. Who designed the system for you? Are they around to help?
Posted 05 July 2021 - 09:39 AM
Cat
A process diagram with design and actual condition (Q,P,T) will be useful to get the trouble in the process , and give you some ideas of what is the issue
Horacio
![]() Psvs Relieving To Closed Drain SystemStarted by Guest__1angelia23_* , 12 Jan 2025 |
![]() Strategy For Adequacy Check Of Multiple Bdvs In A SystemStarted by Guest_nabeelsp1036_* , 22 Jan 2025 |
![]() What Kind Of Cooling System Should I Use To Cool Down A Jacketed MixinStarted by Guest_HollyBoni_* , 31 Jan 2025 |
Using Different Types Of Prvs To Protect The Same SystemStarted by Guest_FarrahC_* , 09 Dec 2024 |
Purging Blowdown SystemStarted by Guest_Ade24_* , 29 Nov 2024 |
