Hi, I'm running PHAST 8.4 for research and modeled a time varying leak release (no Errors whatsoever). during the simulation, i encountered 3 Warnings; the first was that the fluid package switched from a nonideal package to an SRK-idealfugacity package;
2nd, the time-varying discharge model encountered difficulties at a certain time, so it switched to steady state and
3rd, the droplet size was less than the cut-off size (wtv this means) so the droplet did not rain out. (i had a 100+kg of inventory left at this state). This was not solved when i forced correlation to either the mechanical or aero correlation.
i want to get an accurate picture of the time varying discharge; definitely not at steady state. Any advice is appreciated! ![]()
