Math Function Problem
y=ax^5+bx^4+cx^3+dx^2+ex+f how to find x=f(y)
#1 Abdelilah
Abdelilah
  • 25 posts
Posted 10 October 2021 - 08:03 AM
Hi all
I'm not a genius in math. So, any help is welcome :
I've this function :
y = a*x^5 + b*x^4 + c*x^3 + d*x^2 + e*x + f
My query is how to calculate x depending on y. I mean x=f(y).
Thanks in advance.
Edited by Abdelilah, 10 October 2021 - 08:03 AM.
#2 latexman
  • 1,922 posts
Posted 10 October 2021 - 08:14 AM
Numerically, using Newton’s method.
#3 Pilesar
  • 1,687 posts
Posted 10 October 2021 - 03:28 PM
It may not be the academic way, but I would put the y=f(x) function in Excel and use the 'goal seek' feature to target the y value desired by adjusting 'x'. If it did not find solution the first time, I would use a different initial estimate for 'x'. The Excel goal seek uses Newton's method and is pretty robust.
#4 breizh
  • 7,031 posts
Posted 11 October 2021 - 07:34 AM
Consider the paper attached within the link :
http://www.scielo.or...2n2/v52n2a9.pdf
note : let you try your favorite search  engine as I did .
Hope this is helping you
