Globe Valve For On/off Service
valve globe isolation
13 replies to this topic
#1 Estiqaatsi
Estiqaatsi
  • 25 posts
Posted 02 November 2021 - 09:43 AM
In what situations can it be useful or necessary to use a globe valve for an on / off service, as an isolation valve? The situation that I am dealing with is with valves installed on pipes downstream a steam condenser, I was expecting some ball or gate valve. Am I overlooking some obvious aspect?
Edited by Estiqaatsi, 02 November 2021 - 09:44 AM.
#2 Chemitofreak
Chemitofreak
  • 292 posts
Posted 02 November 2021 - 12:30 PM
Never have I seen a globe valve used as a block valve.
#3 Bobby Strain
Posted 02 November 2021 - 04:15 PM
Never is a loooong time!
#4 fallah
  • 5,026 posts
Posted 02 November 2021 - 11:31 PM
Please ensure about on/off service of the valve. In the same situations, downstream of steam condensation, generally a control valve will be installed to automatically adjust the condensate flow rate, say, based on the condensate level; but it might in your case this control valve (normally globe type) will do the job manually.
#5 Estiqaatsi
Estiqaatsi
  • 25 posts
Posted 03 November 2021 - 03:39 AM
Dear Fallah and other colleagues,
thank you for your answers.
As for the on/off service, it is what I have found in a valve list provided by the condenser supplier. It seemed strange to me too.
I'll describe more precisely the situation. It is a revamping of a steam air cooled condenser, where new modules are being added. So a new LP steam line starts from the old one to feed the new modules, and a new condensate line is then connected to the old one, downstream of the new modules. The manual valve is installed on this condensate line. So what I thought, looking at the P&ID, was that a manual globe valve would have been useful to "tune" the system (in addition to adjusting the fans speed during normal operation) and balance the flowrates.
Edited by Estiqaatsi, 03 November 2021 - 03:40 AM.
#6 fallah
  • 5,026 posts
Posted 03 November 2021 - 04:53 AM
Please upload a simple sketch of the system you described for our info...
#7 Estiqaatsi
Estiqaatsi
  • 25 posts
Posted 03 November 2021 - 05:17 AM
https://ibb.co/dpq8QzM
#8 breizh
  • 6,939 posts
Posted 03 November 2021 - 05:24 AM
you may want to read what others said in another forum :
https://www.eng-tips....cfm?qid=301174
the answer seems to be it "depends " !
#9 latexman
  • 1,893 posts
Posted 03 November 2021 - 06:46 AM
They could be for balancing the flows.
Something looks strange on the PFD.  The New Module top right outlet (gas/vapor) is going to condensate and the bottom right outlet (liquid) is going to non-condensibles.  It seems backwards
#10 Estiqaatsi
Estiqaatsi
  • 25 posts
Posted 03 November 2021 - 06:58 AM
sorry, the sketch was made quickly and I was not paying attention to top/bottom placement of the outlet lines. my point was the function of a globe valve installed both on the new condensate and the new non-condensables lines.
Edited by Estiqaatsi, 03 November 2021 - 01:28 PM.
#11 Bobby Strain
Posted 03 November 2021 - 06:26 PM
Seems to me that the valve is only used for isolation. So, any type of valve should be satisfactory. Just needs to be tight shutoff. I presume that there is also a valve on the inlet to the new condenser.
But maybe the designer presumed that a throttling valve could be useful, (or necessary), in directing variable flow to the new condenser. You should talk with the designer. That's the only way you will reach a conclusion.
#12 breizh
  • 6,939 posts
Posted 04 November 2021 - 01:53 AM
You cannot perform service without installing valves at the inlet of the steam condensers !
You may have them installed ,not shown on the drawing .
#13 Estiqaatsi
Estiqaatsi
  • 25 posts
Posted 04 November 2021 - 10:37 AM
Actually I forgot to represent a spacer that they introduced in the new LP steam line (to isolate the new modules, I think, maybe when the weather is too cold; of course this can be made only when the plant is shut down).
Then there is a butterfly valve just downstream of the turbine, but it doesn't seem to be related with the condenser operation.
#14 breizh
  • 6,939 posts
Posted 04 November 2021 - 09:56 PM
If you go for shut down to perform maintenance you don't need isolation valves , this means that the glove valves are throttling valves to balance the streams between the two condensers .
