Effect Of Present Of Methanol In Ethane Feed To Olefin Plants
Posted 28 November 2021 - 07:38 AM
Posted 29 November 2021 - 10:34 PM Best Answer
Methanol is a contaminate containing oxygen. More CO is formed which can poison the acetylene converter catalyst. Oxygenates tend to increase gum formation, leading to problems downstream. Ethylene yields are affected because of the addition of oxygen radicals to the free radical mix of hydrocarbons in the cracking furnace. There will be enhanced risk of corrosion caused by the additional CO, CO2, methanol, formaldehyde, acids, etc, that are formed by the oxygen. Maximum methanol permissible is 'no more than necessary.' Biologically derived feedstocks containing oxygen compounds are cracked in some plants, so it can be done as long as corrosive compounds are carefully monitored.
Posted 01 December 2021 - 03:42 AM
Well described answer, thanks dear. I suppose you have an experience on olefin plants. thanks anyway...
Dynamic Simulation After Feed Flow ReductionStarted by Guest_Kakashi-01_* , 20 Mar 2025 |
Split The Feed Into Two Identical StreamsStarted by Guest_tomr91_* , 16 Mar 2025 |
Gas Hydrate Inhibition: Calculations For Meg/methanol InjectionStarted by Guest_PYG_* , 30 Sep 2019 |
Methanol Water Distillation ColumnStarted by Guest_Kakashi-01_* , 27 Jan 2025 |
