Mawp And Mawv To Determine Pvrv Set Points
#1 vjmenon
vjmenon
  • 3 posts
Posted 16 March 2022 - 09:08 AM
We are trying to determine the maximum design pressure and vacumn for conical fixed roof tanks based on API 650. the client would like to know these values to determine the set points of the PVRV. on further research of the standard, we found the following:
design external pressure shall not be less than 0.25 kpa
internal design pressure shall not exceed 18kpa based on 5.2 Design conditions
Does this mean that the PVRV's cannot exceed 18kpa in operation? If not, please guide on what we are missing here. Along with the calculations, the client would also like an FEA to show that the tanks can sustain the pressures we are indicating.
Any help would be highly appreciated.
#2 latexman
  • 1,893 posts
Posted 16 March 2022 - 09:33 AM
API-650 does not allow any pressure accumulation above internal design pressure, so, yes, "the PVRV's cannot exceed 18kpa in operation" and during an emergency.
#3 vjmenon
vjmenon
  • 3 posts
Posted 16 March 2022 - 09:43 AM
thank you very much for the information. it is highly appreciated.
#4 vjmenon
vjmenon
  • 3 posts
Posted 16 March 2022 - 09:50 AM
Is there any information regarding the limit for the vacuum?
#5 Pilesar
  • 1,635 posts
Posted 16 March 2022 - 10:28 AM
The tank designer sets the design pressures. For the tank to conform to API-650, the rated pressures must be within the range listed in that standard. Not all tanks designed to API-650 standard have the same pressure ratings, but their pressure ratings are in the range allowed by the standard. Use the external pressure spec for the vacuum limit. The difference between internal and external pressures is read on a tank pressure gauge as an internal vacuum.
