For a mixed feed cracker in ethylene plant, wherein liquid gas oil is cracked, due to high volume of higher hcs in this feed, do you think we will need wash oil for fouling control in CGC of this plant ?
Mixed Feed Cracking
Started by CHEMSTRONG, Mar 16 2022 10:07 PM
Posted 16 March 2022 - 10:07 PM
Posted 28 June 2022 - 11:50 PM
Using of Wash Oil solely depends on the cracked gas composition (irrespective of the feed you're cracking). Wash oil will reduce the polymer settled on the compressor internals surface and will form a coating layer there on. So depending on the polymer incursions (butadiene, isoprene, styrene etc.) it has to be decided whether or not to use Wash oil or not.
Handling Of Mixed Or Leaky Petroleum BowserStarted by Guest_Noman97_* , 18 Aug 2025 |
Dynamic Simulation After Feed Flow ReductionStarted by Guest_Kakashi-01_* , 20 Mar 2025 |
Split The Feed Into Two Identical StreamsStarted by Guest_tomr91_* , 16 Mar 2025 |
Effect Of Continuous Blow Down To Boiler Feed WaterStarted by Guest_Dyames027_* , 21 Nov 2024 |
Using Feed Compressor For Start-Up Nitrogen CirculationStarted by Guest_behrouzifar_* , 06 Sep 2024 |
