Estimation Of Performance Curve
8 replies to this topic
#1 panoska
panoska
  • 321 posts
Posted 28 April 2022 - 08:49 AM
Hello everyone,
I have seen that based on operating point of the pump or compressor, it is possible to estimate the performance curve for the pump or the compressor.
At the moment, I am interested in the pump.
Thank you in advance!
#2 Bobby Strain
Posted 28 April 2022 - 09:20 AM
Check the Flowserve site. They probably have pump curves for something close. Or, you probably have the name of the manufacturer for your pump. If so, visit their site.
#3 panoska
panoska
  • 321 posts
Posted 28 April 2022 - 09:32 AM
Thanks Bobby,
I will check it out. Generally, there is not way to make an estimation ourselves. I am aware that this performance curve is based on impeller characteristics. Maybe I have to think a bit more.
#4 breizh
  • 6,879 posts
Posted 28 April 2022 - 10:14 PM
You may find some interest with this link :https://pump-selecto...ASAAEgLm7fD_BwE
many more using your favorite search engine .
#5 panoska
panoska
  • 321 posts
Posted 28 April 2022 - 11:18 PM
Hi Breizh,
Thanks for this. Actually, I would prefer to make a rough estimation myself and not to connect any vendor yet. ☺️
#6 breizh
  • 6,879 posts
Posted 28 April 2022 - 11:25 PM
This is not going to happen , the only estimation I'm aware of is the efficiency of a centrifugal pump vs flow rate and head published by Carl Branan in his book "Rules of thumb for chemical engineers" 4th Edition .
another reference:
https://www.pumpfund...ok/chapter4.pdf
Edit :
Consider this literature :
https://www.scielo.b...TXq6z/?lang=en#
#7 Art Montemayor
Posted 29 April 2022 - 09:12 AM
Panagiotis:
As usual, Breizh is exactly correct.  His technical library is an engineer's gold mine.
I also have a hard copy of the mentioned book and I transcribed the attached article that Breizh mentions.  I cleaned it up a little.  Mr. Branan was not that good of a writer; but he obviously was a great practical engineer.  What he did was: he took some published centrifugal pump performance curves issued by the old contractor, M.W. Kellogg and he regressed them to obtain an equation.  I am from his generation and I can imagine that he probably regressed the curves with manual calculations using the method of Least Squares - not much fun.  Today, I can do it with a computer program in a few minutes.  You could do the same.
You don't give us any background or reasons for your query.  I hope this helps you in whatever you are doing.
Attached File  Centrifugal Pump Efficiency Estimation.docx   18.53KB   24 downloads
#8 panoska
panoska
  • 321 posts
Posted 29 April 2022 - 01:17 PM
Hi Art,
Thanks for your reply. I wanna transfer liquid between two atmospheric tanks.
I know the flow rate and I calculated the corresponding head.
My aim is calculate the estimated performance curve by knowing this operating point.
#9 Bobby Strain
Posted 29 April 2022 - 08:47 PM
That's not the way to get to the right pump. You find a pump curve from the Flowserve site that fits your requirements. Nobody does what you are contemplating.
We all followed a red herring!
Edited by Bobby Strain, 01 May 2022 - 11:10 AM.
