Separator Carryover
hysys 3-phase separator carry over
#1 R_Gowtham
R_Gowtham
  • 15 posts
Posted 18 May 2022 - 04:50 AM
Greetings,
While mention the 3-phase separator in hysys, how much carryover should i mention?
Is any specification for this carryover like light in heavy phase, heavy in light, gas in light phase?
  • 1,637 posts
Posted 19 May 2022 - 06:25 AM
Phase separators in simulation are usually assumed to be ideal separation for most purposes. Put whatever carryover you need for your specific application to match your process. If you are troubleshooting downstream equipment and want to see what a little liquid in the vapor would look like, then dial some in. Simulators are a tool with a lot of options that may be rarely used.
#3 sybase666
sybase666
  • 9 posts
Posted 06 June 2022 - 04:18 AM
yes, in hysys dynamic simulation mode, for vessel, you can do this, like liquid in gas, gas in liquid, it can be based on feed, product or composition something.
#4 horatorres
horatorres
  • 88 posts
Posted 13 June 2022 - 11:19 AM
Carryover means the liquid leaving in the gas phase. It is specified as a design parameter.
You can find this value by hand according to your process requirements. Later chek on with the simulator, that has to bi given as input data.
Horacio
#5 breizh
  • 6,940 posts
Posted 14 June 2022 - 04:27 AM
Consider to study the material attached .
#6 Santosloera
Santosloera
Posted 04 July 2025 - 02:15 PM
hi breizh, where is the material ?
Edited by Santosloera, 04 July 2025 - 02:16 PM.
#7 breizh
  • 6,940 posts
Posted 04 July 2025 - 04:27 PM
As per request
