Chemical Kinetics Question
chemical kinetics kinetics
#1 Lukaline
Lukaline
Posted 24 May 2022 - 04:50 PM
a)Given the 2A--->B reaction that takes place in the gas phase with the aid of a PBR compensation device. Calculate the mass required for a 40% conversion. Adopt that the pressure can be considered constant.
b ) Repeat the item a) in case of pressure drop.
c) Repeat item b ) for another particle diameter (2x larger, for example), and compare the results.
Edited by Lukaline, 24 May 2022 - 04:51 PM.
  • 6,940 posts
Posted 24 May 2022 - 07:37 PM
We don't do homework but we are happy to help . Share with us your work and difficulties you are facing ,someone is going to help you.
note : you can find videos on Youtube channel for this type of problem , key words Pressure drop in PBR reactor
Hope you understand.
