Edited by Futur123, 16 June 2022 - 08:01 AM.
Posted 16 June 2022 - 07:55 AM
Posted 16 June 2022 - 10:11 AM
Why would you want to do this? Information is readily available for gas turbine net output.
Posted 16 June 2022 - 12:33 PM
Thank you for your answer.
I did not set the net power (W net) produced by the turbine.
The "W_turbine" do not take in consideration the power used by the compressor.
So am asking how to set the net power of the gas turbine which is equal to "W turbine minus the power used by the compressor (W c) "
Steam Carrying Liquid From The Sour Water Stripping TowerStarted by Guest_kaidlut_* , 12 Sep 2024 |
Energy Analysis In Aspen Plus 14.2Started by Guest_Sarishma_* , 23 Mar 2026 |
