Compressor Discharge Controller
#1 ali99
ali99
  • 14 posts
Posted 08 July 2022 - 02:47 AM
Good morning / evening ,
   We have for PYGAS unit twin rotary compressor  for recovery the hydrogen , the discharge controller maintain the discharge flow 7 tons , in case emergency we loss the hydrogen & the compressor be under circulation , the discharge controller if Auto will close to maintain the pressure & the discharge flow will come down & will trip the compressor . I have suggestion to install minimum close limit 50% for discharge controller .
Any advised will be appreciated.
  • 6,908 posts
Posted 08 July 2022 - 03:28 AM
You should stick to your operating manual and follow manufacturer's recommendation . Prior to do anything contact them to acknowledge your proposal with a written reply .
Note : Make sure you are clear about anti surge system and control .
my 2 cents
#3 ali99
ali99
  • 14 posts
Posted 09 July 2022 - 01:19 AM
Thank you MR Breizh for your support. .
#4 horatorres
horatorres
  • 88 posts
Posted 13 July 2022 - 08:41 PM
The anti-surge will run the compressor recycling the gas to keep the unit out of the surge limits.
I Assume your compressor has not it installed.. ????
You must install an anti-surge system as a priority engineer task
Horacio
