Flow Calculation
#1 Venkat @89
Venkat @89
  • 87 posts
Posted 21 July 2022 - 08:21 AM
Dear all,
As panel engineer, I always find flow transmitters getting faulty, during such situation before getting it attended through instrument team, is it possible to calculate flow if I know the upstream(14kgf/cm2g) Debutanizer column and downstream pressure(2kgf/cm2g) flow towards storage tank across the control valve, whose opening is 55%?
If so, what data I need to use to get the flow?
Edited by Venkat1989, 21 July 2022 - 08:22 AM.
#2 latexman
  • 1,928 posts
Posted 21 July 2022 - 09:32 AM
I recommend you refer to your university fluid flow textbook, or obtain Crane Technical Paper No. 410.
#3 breizh
  • 7,058 posts
Posted 21 July 2022 - 10:07 PM
I think Latexman is spot on with his recommendations.
As a panel engineer you should be able to explain your thoughts based on DCS trends thus ask support from I&E team.
Note : You should be able to ask your process engineer to come and use a portable  non intrusive flowmeter to support you ( doppler flowmeter device) . This is a cheap investment for a plant and can help a lot to troubleshoot units and get data .
#4 Said Salim
Said Salim
  • 98 posts
Posted 22 July 2022 - 01:15 AM
You can use your historical data before flow transmitter failure and plot flow reading against CV opening and derive the correlation.
#5 Pronab
Pronab
  • 166 posts
Posted 24 July 2022 - 02:25 AM
Usually there are flow vs valve opening at specified CV provided by the manufaturere where you can find out the flow at your desire valve opening.
#6 breizh
  • 7,058 posts
Posted 24 July 2022 - 11:26 PM
I still believe the best way is to use an external flowmeter to validate your suspicion of a faulty flowmeter or valve , see my initial reply..
Anyway you will find a excel sheet with equations and methodology to support your query . To perform the exercise you need information about the valve (CV) together with its type of response ( see attached document) and piping arrangement ( length, fittings).
