Relative Humidity In Aspen Plus
#1 CHEMSTRONG
CHEMSTRONG
  • 348 posts
Posted 25 July 2022 - 09:20 AM
I have HC gas composition in stream no 1 and Water in Stream no2 and we are mixing these two streams to get final stream No3 . I want to maintain relative humidity of 80 percent in stream no3 using ASPEN PLUS software herein ?
I am not able to find relative humidity as a parameter in ASPEN PLUS here ?
Thanks.
Best Regards,
CHEMSTRONG
  • 1,637 posts
Posted 25 July 2022 - 09:46 AM
Why not just calculate the amount of water needed to saturate the hydrocarbon then multiply that amount by 0.8?
#3 CHEMSTRONG
CHEMSTRONG
  • 348 posts
Posted 25 July 2022 - 11:50 PM
Ok, do you mean doing this procedure, it will do exactly same thing in ASPEN PLUS ?
#4 PaoloPemi
PaoloPemi
  • 550 posts
Posted 28 July 2022 - 06:33 AM
follow Pilesar's advice,
by definition relative humidity is the amount of water in vapor phase expressed as a percentage of the maximum amount of water vapor the mixture can hold at the same t, p conditions.
I am not familiar with Aspen (I have Prode Properties which allows to extract individual component's fractions and then calculate these values in Excel or Python with some programming language) but you can (for example) calculate t,p,w at saturation (as reference value) and then iterate until the requested condition is met...
