Determining Chemical Injection Rate Using Drawdown Guage
#1 CHEMSTRONG
CHEMSTRONG
  • 348 posts
Posted 08 August 2022 - 08:14 AM
Dear Sir,
How to determine chemical  injection rate using Dradown Guage  in chemical plant ? in field ? or manually?
  • 6,932 posts
Posted 08 August 2022 - 11:16 PM
A) part of the skid supplied by vendors of chemicals , do you really need it ?
B) what I 've seen is a three way valve at the discharge of the pump to transfer the flow to a capacitance  ( 100 to 200 ml) . At the same time you count the time (s) to feel the volume and you get your flowrate .
it's up to you , not much money involved .
Note : you should discuss with your peers or manager prior to ask to forum members.
