Compressor Load Sharing Issue
Started by Ogg291, Aug 21 2022 09:21 AM
Posted 21 August 2022 - 09:21 AM
We have 3 natural gas compressors in our system. However we sometimes use 2 compressors when demand is low
Our issue is when we have two compressors operating and one compressor shuts down, the other compressor load decreases gradually resulting in the shutdown of the second compressor too. Any idea why this could happen
Posted 21 August 2022 - 12:55 PM
What you described makes no sense. What do you refer to as "load"?
Edited by Bobby Strain, 21 August 2022 - 02:42 PM.
Posted 21 August 2022 - 09:52 PM
Thank you for your reply, the load refers to compressor flow
Posted 21 August 2022 - 10:07 PM
In critical gas compression systems, you must have a spare unit... It is your case, search for more information.. it is too weak to said something,
horacio
Aspen Plus Rcstr Convergence Issue – Mass Balance Error In Anaerobic DStarted by Guest_Marie26_* , 05 Apr 2026 |
Spray Dryer Nozzle Issue – Pressure Increase And Fines IncreaseStarted by Guest_Ella2365_* , 24 Mar 2026 |
Organic Peroxide Distillation IssueStarted by Guest_Kimbreaux_* , 19 Feb 2026 |
