Hysys Dynamic Simulation, Negative Mass Flow
dynamcis aspenhysys flow
#1 Seung
Seung
Posted 22 September 2022 - 06:25 AM
Hi
I want to simulate a two stage brayton cycle with Aspen HYSYS V11 for H2 liquefaction plant.
So, I build a simple two stage example and run it. But, when I start it  in dynamcis, it has a negative mass flow (seems like flow is reversed).
It looks good in steady state (with 204 g/s of helium). How can I fix it ??
This is my flowsheet and workbook
Edited by Seung, 22 September 2022 - 06:29 AM.
  • 1,557 posts
Posted 22 September 2022 - 01:41 PM
Try putting a flow control loop in the dynamic simulation. Dynamic simulations are picky about details. It may be worth your time reviewing some training materials.
#3 latexman
  • 1,819 posts
Posted 22 September 2022 - 02:01 PM
I use a simulator occaisionally.  I am no expert.  And, I have never used a dynamic simulator.  The mass/molar flow is positive.  That's good.  The temperature of the stream is decreasing from start/inlet to finish/outlet.  That's good.  And, the heat flow is decreasing from start/inlet to finish/outlet, which, in my mind, aligns with the temperature decreasing.  Yes, steady-state looks good.
Try putting a check valve in the line.
