Recip Compressor Discharge Prvs
Posted 15 October 2022 - 03:13 AM
1. As the stage 2 thru stage 6 PRV discharges are combined into a sub-header, could there be a scenario where more than one stage PRV is relieving? My understanding is it is not credible as I do not foresee see any common mode failure. Recycle valve controller failure and blocked outlet should not be considered simultaneously as independent events. Each recycle valve is sized for 100% recycle.
2. For 3% inlet line losses criteria, should the line start from discharge pulsation dampener up to the PRV inlet or just the PRV inlet line section? PRV is located on the discharge piping about 20 metres from the compressor.
Posted 15 October 2022 - 07:30 AM
My opinions for what they are worth... probably not worth a lot since I tend to argue with designers of my relief valves. Sometimes I win, usually I don't.
I don't see a common mode failure from your description.
The 3% rule doesn't make sense in these scenarios (probably my opinion only) since the cause is mechanical pressuring of non-condensable. Valve chatter seems so unlikely to me here in any reasonable scenario. But if you must conform to 3% inlet rule, then I think it should be calculated from the source unit the PRV is protecting and include the discharge piping.
These opinions are to contribute to discussion and not authoritative.
Posted 03 February 2025 - 09:25 AM
In any scenario, for recip machines PRV will not pop. As we usually have 2oo3 logic of either PT or TT's on the discharge line which will trip the machine
Compressor Selection Based On Flowrate & Compression RatioStarted by Guest_Dhams_* , 19 Jan 2026 |
Purge Gas For Centrifugal CompressorStarted by Guest_Lyne_* , 19 Oct 2025 |
Igv Control For CompressorStarted by Guest_Lyne_* , 30 Aug 2025 |
