Can somebody provide me with a process flow diagram for the metal oxide process when making formaldehyde ?
Metal Oxide Process (Formaldehyde)
Posted 07 November 2022 - 08:56 AM
Posted 07 November 2022 - 01:44 PM Best Answer
simple formaldehyde process pfd here: https://ibb.co/d01KKRf
From the formaldehyde entry in the Kirk-Othmer Encyclopedia.
Edited by Pilesar, 07 November 2022 - 02:15 PM.
Posted 08 November 2022 - 06:03 AM
Thank you so much
it wasn't that i was unable to find diagrams it was because there were many variations so i was unsure what to base my drawing off. I have to combine this process with the production of novolacs.
Instead of phenol i decided it would be better to use cresol and the formaldehyde. Im aware that there is a batch resin reactor and batch distillation equipment but i haven’t found any clear pfds for it. Maybe i am wording it incorrectly when I search it up but coul i have some help?
Posted 08 November 2022 - 06:18 AM
You should give Pilesar a like (green arrow instead of red) .
Posted 08 November 2022 - 09:50 PM
Thanks, Breizh. Arrow is no problem. I web-searched "cresol formaldehyde novolac resin" and found lots of results. Academic papers are usually pretty good since they contain material balances. Patents are an okay resource, but I don't think as useful as academic papers. The process design patents I usually find are only patents because they are 'different' which is not what you are looking for. Sometimes patents describe the usual way of doing things before describing the new idea but still I prefer to read someone's master's dissertation. You just have to do the research.
Posted 08 November 2022 - 11:28 PM
This situation is subject to what is named Process Design and Process Licensing. Be informed that final cost of both options can become surprisingly high.
Note that price of cresols is much higher than that of phenol so a resin should have superior properties to justify resources and time spent to a new product&process design or cost of a royalty to a Licensor.
Edited by shvet1, 08 November 2022 - 11:29 PM.
Posted 09 November 2022 - 06:45 AM
My experience, a long time ago, in phenolic resins was the regulations, operability, and cost of vent and waste water treatment was a major hurdle to profitability.
Mastered Process EngineeringStarted by Guest_Boudinahh8777_* , 31 Oct 2025 |
Ethylene Oxide Off-SpecStarted by Guest_Movers_* , 25 Feb 2026 |
Gas Sweetining ProcessStarted by Guest_Alameerha_* , 10 Nov 2025 |
Seeking Feedback On My Process Flow Diagram. Biogas Steam Reforming ToStarted by Guest_Jacobaum_* , 27 Oct 2025 |
Urea-Formaldehyde ModelingStarted by Guest_Lyne_* , 21 Oct 2025 |
