How To Change Saturated Steam In Dry Steam In Heat Exchanger
#1 Orzelgorskiego
Orzelgorskiego
  • 28 posts
Posted 13 November 2022 - 06:20 PM
I have saturated steam at temp 160degC. Is it possible to heat up this steam in shell and tube heat exchager and obtain dry steam?
Thank you for help.
Tomasz
  • 1,635 posts
Posted 13 November 2022 - 10:22 PM
Saturated steam can be superheated and often is superheated in coils in the convection section of fired equipment. What do you have in mind as a heat medium for your steam exchanger? Usually steam at such low pressures is not worth superheating from saturation conditions. Steam traps are used to remove condensate. What extra value would you have if the steam were superheated? Would that extra value pay for an exchanger and heating medium?
#3 shvet1
shvet1
  • 476 posts
Posted 13 November 2022 - 11:34 PM
Yes, it is. Be ready this option might become surprisingly expensive.
#4 breizh
  • 6,939 posts
Posted 14 November 2022 - 04:34 AM
Can you share the background? What will be the heating source?
What is the quantity? you may want to consider a dry steam generator for this specific application.
More inputs are welcome.
#5 Orzelgorskiego
Orzelgorskiego
  • 28 posts
Posted 14 November 2022 - 10:03 AM
Thank you for all answers. In general I would like to use biomass to create dry steam.
I was looking for different equipment on the market and I found biomass steam generator with capacity of 200kg/hr which is producing saturated steam at temp 170deg C and pressure 0.7MPa. I was thinking that I can heat up this steam and create dry steam in heat exchanger. Is it possible?
#6 Orzelgorskiego
Orzelgorskiego
  • 28 posts
Posted 14 November 2022 - 10:04 AM
Dry steam generator will be perfect, but heating source biomass, not electricity.
#7 SilverShaded
SilverShaded
  • 237 posts
Posted 16 November 2022 - 03:01 AM
Steam is frequently superheated in shell and tube exchangers for example on crude oil atm/vacuum unit product rundown lines.  On the other hand, why not just use a furnace and raise the steam in the radiation section and superheat it in the convection section?  Or less economic, compress the staurated steam to a higher  pressure, in which case it will be dry.
Edited by SilverShaded, 16 November 2022 - 03:02 AM.
