Modelling Simple Mass And Energy Balance Of Ammonia Synthesis Loop?
ammonia matlab model
#1 AnupPaudel
AnupPaudel
Posted 19 November 2022 - 08:48 AM
Hi there, I want to design the simple model of ammonia synthesis loop. I don't want to use aspen. I want to do this in Matlab.
This model should calculate mass and energy (how much heat required and removed) balances, effects on ammonia production due to presence of impurities, and pressure drops. I don't want to integrate reaction kinetics in the model with complex differential equations to calculate mass and energy balances?
Is there some simiple empirical relations or something like that to make this simple model? I am totally new to this field. Please give me some suggestions on this.
  • 1,635 posts
Posted 19 November 2022 - 02:10 PM
Your goal can be accomplished to an extent. In the 80's I developed material balances for the ammonia process using complicated Lotus 1,2,3 spreadsheets for designing grassroots plants. You will need an understanding of how your variables affect results and code the mathematical relationships. You will also need at least one accurate material balance for checking your program. If you use that balance for tuning, then you should have at least one other balance for the checking. Calculating changes in the loop reactor itself will be difficult due to their complex geometry, so first assume a fixed percentage conversion to get the rest of the loop correct. If I were to attempt your task, I would search on the web for references. Academic thesis work for the ammonia process was common and often contains useful material balances if you have no better resource.
  If you are interested in the fascinating history of the ammonia process (the birth of chemical engineering) I recommend the book 'The Alchemy of Air' by Thomas Hager which traces the story of Fritz Haber and Carl Bosch. The mass production of ammonia averted worldwide starvation allowing the population growth we have seen in the past 100 years.
#3 breizh
  • 6,937 posts
Posted 20 November 2022 - 02:15 AM
Did you try Google?  key words simple model of ammonia synthesis loop
Literature available.
https://pubs.rsc.org...8/ra/c8ra06821f
