In CPI bellows are used in PSVs preventing PSV body & downstream piping from corrosive process fluids in severe applications. These bellows over a period of time have got punctured causing corrosion problems in case PSVs starts passing. Our OEM has indicaed that these models Of PSVs have become obsolete & spares are not available. Now we are in the process of purchasing these bellows from third parties. Is there any standard / specification available for bellows(eg Specifying the no. of cycles)? Thanks in advance..
Psv Bellows
Started by ASH25320, Nov 16 2006 05:27 AM
Posted 16 November 2006 - 05:27 AM
Posted 16 November 2006 - 06:35 AM
Are you talking abouit Pressure Safety Valves?
In the area of process safety, a bellows PSV usually refers to the type of relief valve that is less dependent on built up or variable back pressure; therefore your description confuses me. Please clarify who is the manufacturer and the model number you have.
![]() Balanced Bellows Relief ValveStarted by Guest_farid.k_* , 20 May 2020 |
Bellows Type Relief Valve In Cryo ServiceStarted by Guest_Sara Owens_* , 29 Nov 2018 |
Bellows DamageStarted by Guest_rohollah_* , 15 Apr 2013 |
Back Pressure Correction Factor For Balanced Bellows PsvStarted by Guest_rohollah_* , 21 Jul 2012 |
Use Of Expansion Bellows In Flare LineStarted by Guest_fimmi_* , 29 Nov 2011 |
