I am designing a storage tank for a project which stores acetonitrile which is flammable, combustible and corrosive. What standards should I be looking at?
Design Of A Storage Tank
Started by Manue, Feb 11 2023 02:30 PM
Posted 11 February 2023 - 02:30 PM
Posted 11 February 2023 - 07:45 PM
To start with consider these documents attached. You should also refer to MSDS of your product and most probably to handbook supplied from Vendor of this product.
A google search will certainly help you.
https://www.ineos.co...le_brochure.pdf
My 2 cents
Posted 13 February 2023 - 10:28 AM
Thank you so much
