Aspen Hysys - Desalter Sizing
#1 tsewell
tsewell
Posted 19 February 2023 - 06:07 PM
Hi all!
I am trying to simulate a crude oil desalter in Aspen Hysys using a 3-phase separator, but I am running into some issues. The problem statement requires the crude oil/water mixture to be liquid and no vapor product exiting the desalter. However, when I try to use the "quick size" button in the ratings tab, Hysys tells me it cannot be sized because there is no vapor product. Is there a way to size a 2-liquid phase separator without vapor in Hysys? If not, what are the best sources to go to to size a desalter by hand?
Thanks!
  • 1,635 posts
Posted 19 February 2023 - 06:19 PM
Try adding a little nitrogen to your stream to trick the software.
#3 tsewell
tsewell
Posted 19 February 2023 - 08:14 PM
Thanks, that's sneaky! I threw in a lbmol/hr and it was able to size it. Unfortunately a little bit of the nitrogen ended up in the crude stream, so if anyone happens to have a non-tricky way to do this I'd still love to hear it.
#4 SilverShaded
SilverShaded
  • 237 posts
Posted 20 February 2023 - 05:05 AM
The three phase seperator sizes vessels based on vapour/liquid seperation and a rule of thumb for residence time, there is no way you can realistically use it to size a desalter which is seperatng oil/water emulsion with an electrostatic field.
