Effect Of Lighter Components On Overhead Composition Control
7 replies to this topic
#1 Venkat @89
Venkat @89
  • 87 posts
Posted 23 February 2023 - 02:32 PM
Italic written matter is from book written by Norman Liberman sir, Effect of Lighter components on Overhead Composition control. I have doubt in it. Can Someone guide me.
Effect of Lighter Components on Overhead Composition
Control
I noticed on my depropanizer in Texas City that the butane content of my
propane product was erratic, even though the tower top pressure and
temperature were constant. However, when I studied the lab data closely, I
noticed an interesting trend. When the ethane content of the propane
product was high, so was the butane. As the ethane content of the
depropanizer feed became erratic, so did the butane content of the propane.
But why?
The vapor leaving the top of a tower is at its dew-point temperature and
pressure. As the ethane content of a propane vapor stream flowing at its dew
point goes up, the dew-point temperature will decrease. The ethane makes
the propane more volatile. If the reflux rate is on tower-top temperature
control, the lower dew-point temperature will reduce the reflux to restore the
temperature set point. The reduced reflux flow permits more butane to be
distilled overhead.
The resulting variable butane content of the overhead product reflects not so
much a malfunction of the temperature control, but a natural variation in the
overhead ethane content. What I eventually did on my depropanizer was to
integrate the online gas chromatograph (GC) to reset the tower-top
temperature set point for ethane and butane composition. Now, with
advances in computer control, this technique has become common.
It is very clear, when the Ethane content increases in top vapor containing Propane, it is obvious that dew point temperature decreases.
Keeping top temperature of the column set value as same as before, firstly why does reflux flow gets reduced as mentioned in the paragraph, when ethane content in top vapor increases?
Can Someone help me to understand? Thank you.
#2 Vegeta
Vegeta
  • 133 posts
Posted 24 February 2023 - 01:44 AM
Can you describe the overhead control, please?
#3 Venkat @89
Venkat @89
  • 87 posts
Posted 24 February 2023 - 05:03 AM
The italic written paragraph is from Norman Lieberman sir's book.
Pressure control philosophy not mentioned.
#4 SilverShaded
SilverShaded
  • 237 posts
Posted 24 February 2023 - 06:18 AM
It's simply saying that at constant dewpoint temperature, increasing ethane also increases butane to keep the same dewpoint.
#5 halkeshhulk
halkeshhulk
  • 25 posts
Posted 08 March 2023 - 01:39 AM
Absolutely true, to maintain constant dew point when lighters than distillate gets increased, heaviers that distillate needs to increase to maintain constant dew point. Agree.
But I didn't understand this below statement used in the paragraph.
distilled overhead
If the column top temperature is kept constant, why does reflux gets reduced?? Please explain.
#6 SilverShaded
SilverShaded
  • 237 posts
Posted 08 March 2023 - 02:53 AM
distilled overhead
I think it's because although the bubble point is constant (ie top tray temperature) the dew point reduces, so the condenser and reflux are cooler.  I assume from whats written that as ethane and butane are increased the bubble point stays the same but the dewpoint decreases.  I've not tried it but 5 minutes in a simulator would confirm if its true or not.
#7 breizh
  • 6,937 posts
Posted 08 March 2023 - 06:13 AM
If you don't have access to simulator, you may use the calculator attached.
https://checalc.com/...stillation.html
You will find details in the reference attached to the document.
I believe this will help you to solve your problem
#8 halkeshhulk
halkeshhulk
  • 25 posts
Posted 09 March 2023 - 11:54 AM
Thanks sir
