How Does Capacity Control Based On Speed Work For Recip Compressor?
compressor reciprocating capacity control capacity control compression positive displacement
#1 zamakaze
zamakaze
  • 14 posts
Posted 15 March 2023 - 03:10 AM
How does VFD speed control actually work in Reciprocating/Positive Displacement Compressor?
In case of reciprocating compressor, how does capacity control work with speed control. Since we don’t really measure capacity / flow, is the speed control done based on pressure?
For example lets assume a machine designed for 300 NM3/hr of gas with 3 bar suction pressure at full speed. In normal conditions, we get 300 NM3/hr supply from source at 3 bar and compressor happily compresses the gas working at full speed. Now lets say , the flow is reduced to 150 NM3/hr…in this case what will Compressor respond to? Is it the fact that suction pressure starts reducing as the Compressor initially at its full speed wants to move 300 NM3/hr? And as suction pressure reduces, the compressor speed is reduced to maintain same suction pressure which in turn reduces capacity of compressor? Is this correct understanding?
#2 sonu19921103
sonu19921103
  • 12 posts
Posted 18 March 2023 - 06:07 AM
There are a number of capacity control mechanisms for the recip compressor; some of them re listed below: -
  • Recycle (the gas from the compressor discharge is cooled and recycled back to the compressor on Suction pressure control).
  • VFD (The number of stokes is manipulated based on the compressor suction pressure).
  • Loaders and Unloaders (they kind of manipulate the volumteric eff of the compressor).
Best Regards
Sonu Singh
#3 breizh
  • 7,036 posts
Posted 20 March 2023 - 12:28 AM
You may need to get a copy of the book in reference: a chapter is dedicated to reciprocating compressor and control.
Compression machinery for oil and gas   ELSEVIER 2019   ISBN: 978-0-12-814683-5
https://www.scienced...apacity-control
