There is the following task in HYSYS.
It is required to specify a substance that is not in the databank. In fact, there is no exact component composition or distillation.
But there are thermophysical properties (density, viscosity, thermal conductivity, saturated vapor pressure) with a sufficiently detailed temperature step (20 points).
In HYSYS, it is required to solve cases with hydraulics and heat transfer, recycles and adjusts.
It will be a closed circuit with heat exchangers and pipelines.
How do it in HYSYS?
Manual Creating New Component And Setting Properties In Hysys
Started by Platonicus, Mar 15 2023 02:34 PM
Crude Assay Pure Component AdditionStarted by Guest_darknight1991_* , 17 Jan 2026 |
