If a line has a control valve and assume that it has different flow rates, say for eg 100 kg/hr, 150 kg/hr, and 200 kg/hr, can anyone tell me in which flow rate the delta P is higher? delta P across control valve. Kindly help.
Pressure Drop In Control Valve
Started by krishnamurthy, Mar 22 2023 08:17 AM
Shell And Tube Pressure DropStarted by Guest_UofUChemE_* , 08 Jun 2018 |
Vacuum Total Condenser With Flooded Surface Control During TurndownStarted by Guest_unvecchietto_* , 02 Jul 2026 |
How To Size A Presure Equalization Line For A 10" Pipeline ValveStarted by Guest_Rerrizftt_* , 14 Jul 2026 |
Thermal Relief Valve For A Fire CaseStarted by Guest_QuantumEng_* , 19 Nov 2025 |
