If a line has a control valve and assume that it has different flow rates, say for eg 100 kg/hr, 150 kg/hr, and 200 kg/hr, can anyone tell me in which flow rate the delta P is higher? delta P across control valve. Kindly help.
Pressure Drop In Control Valve
Started by krishnamurthy, Mar 22 2023 08:17 AM
Vapor PressureStarted by Guest_Hamza1111_* , 23 Mar 2024 |
Vacuum Ejector Pressure ControlStarted by Guest_himanshu.ch_* , 19 Mar 2024 |
High Pressure Condensate Recovery To Low Pressure DeaeratorStarted by Guest_hd_1982_* , 16 Feb 2024 |
Self Actuated Pressure Reducing ValveStarted by Guest_panagiotis_* , 16 Feb 2024 |
