I am facing an issue while evaluating the PSV of an existing plant.
A heating medium (steam, tube side) vaporizes a hydrocarbon (n-pentane, shell side) in a vaporizer heat exchanger.
Vessel is constructed in accordance with ASME BPVC VIII Div1.
Design pressure of the system is 29 barg at the shell side.
Critical point of n-pentane is 32.7 barg and 196.55 °C.
For a blocked outlet scenario on the pentane side with heating medium continuing I am facing the following issue.
- Single pressure relief valve, 110% accumulated pressure = 110% x 29 = 31.9 barg which is very close to the critical pressure.
This gives excessive relief rates because of the relatively low heat of vaporisation (orifices size ~ 66000 mm2 or 4x 8T10).
- Multiple pressure relief valves, 116% accumulated pressure = 116% x 29 = 33.6 barg which is above the critical pressure.
This gives much smaller relief loads because the heat transfer in the supercritical region is much smaller compared to the normal boiling, sub-critical, regime in combination with temperature pinching between steam and pentane side.
- Fire scenario, 121% accumulation, will also transition the system into the super-critical region.
Relief loads and maximum mass flux / orifice sizes have been derived using the rigorous method as per Ouderkirk and API STD 520 C2 respectively.
For 116% accumulation, blocked outlet, the required orifice area is around 3450 mm2, say a 4P6.
For 121% accumulation, fire case, the required orifice area is around 7400 mm2, say 2 times a 4P6
Would it be ok to install 2 x 4P6? (1 PSV for the process scenario and 2 PSV for the fire case)
One could argue that in this case there is only 1 PSV for the process (non-fire) scenario and a max. accumulation of only 10% is allowed.
Problem is that 1 x 4P6 at 110% would not cover the relief scenario because of subcritical, but 1 x 4P6 would be sufficient at 116%.
Or does the process scenario (blocked outlet) need to be covered by multiple relief devices in order to be able to use the 116% accumulation?
Then, I would end up with:
2 times 4L6 ( ~ 3682 mm2) to cover the process scenario (blocked outlet) and being able to use 116% accumulation.
And a 4P6 in addition to cover for the fire case as well.
Note: the system currently only has a 1x 4M6 PSV hence needs upgrading.
In case 3 PSVs are required it would become something like 4M6 + 3K4 (or 4L6) + 4P6.
I would appreciate your help in interpreting ASME BPVC VIII with respect to number of relief valves required or any other insights you might have.
