Generating Valve Characteristic Curve Using Iterations
valve excel
8 replies to this topic
#1 IonCube
IonCube
  • 62 posts
Posted 15 April 2023 - 06:38 AM
I have Chinese valves where from nameplate I can get Cv @100% open & that its Equal%.
Now I generated a spreadsheet model which is fairly simple & then used 'Goal Seek' feature to iterate values such that I get stated Cv at 100% opening.
I am uploading procedure that I followed (this document also has a small video file)
I am also attaching spreadsheet file as well.
External server zip file: Characteristic Curve Generation (mediafire.com)
  • 6,936 posts
Posted 16 April 2023 - 04:39 AM
Thanks for sharing, in the same vein you may be interested with this spreadsheet.
#3 Pilesar
  • 1,635 posts
Posted 16 April 2023 - 08:01 AM
Chemical Engineering June 1997 article by Ron Darby is the source of that spreadsheet. I do not have a copy of the journal article, but I have a copy of a book Darby wrote 'Chemical Engineering Fluid Mechanics' which maybe some day I will go back and read.
#4 breizh
  • 6,936 posts
Posted 16 April 2023 - 08:36 PM
For those interested with the paper from Ron Darby, check the attachments.
#5 Pilesar
  • 1,635 posts
Posted 17 April 2023 - 12:32 AM
Breizh, the spreadsheet looks to be your work and seems to go much further than the Darby article. There are many hours of development in the spreadsheet and will deserve many hours into understanding its features. Thank you.
#6 breizh
  • 6,936 posts
Posted 17 April 2023 - 12:54 AM
Hi Pilesar,
Yes, this is my work like most of the spreadsheets I shared in this forum. It was a time where Chemical engineering magazine was the unique source of information, before internet.
#7 IonCube
IonCube
  • 62 posts
Posted 17 April 2023 - 03:03 PM
@ breizh, Pilesar
Friends I am not selecting a valve, the valve already is there. I am in rating mode you can say. So I just want to know that is my generated curve from nameplate information is OK. Because I want to know at say 40% what amount of Cl2 this valve can throughput
#8 breizh
  • 6,936 posts
Posted 17 April 2023 - 08:52 PM
Pay attention that valve is one component of your system. You need to assess the entire system (piping, fittings...).
The valve should operate within the 50-70% range for good control.
#9 IonCube
IonCube
  • 62 posts
Posted 18 April 2023 - 01:13 AM
An optimized PDF, thanks for uploading
