Has anyone heard of an integral acid gas/main flare tip? For example a steam traced and insulated acid gas flare (6") would be run up the side of a larger main flare stack (20") and the acid gas would be introduced into the center of the main flare tip. This would avoid additional pilots for a separate acid gas flare tip.
Integral Acid Gas/main Flre Tip
Started by sanderson51, May 06 2023 12:40 PM
Phosphoric Acid 56% Tank LiningStarted by Guest_Phosphoric123_* , 20 Apr 2025 |
Slope Of Flare Sub Headers / Tail Pipes And Main HeadersStarted by Guest_Sawsan_* , 02 Dec 2024 |
Equilibrium Data For Nitric Acid And WaterStarted by Guest_ksagarzazu_* , 07 Oct 2024 |
Acid Base ExtractionsStarted by Guest_paradoxlost_* , 07 Jul 2024 |
