Restricted Orifice Sizing
Posted 11 May 2023 - 12:12 PM
I want to know how to calculate restricted orifice plate dia if my line size is 4 inch and flow rate is 83 kg/hr and material density is 1145 kg/m3 ,I have to do 996 kg control addition in 12 hour's.
Posted 11 May 2023 - 01:42 PM
You need a metering pump.
Posted 12 May 2023 - 12:42 AM
https://www.lmnoeng.com/orifice.php
https://sheet.zohopu...3e93d?type=grid
or contact a vendor
I agree with above - orifice is not suitable for dosing, dedicated means are preferred.
Posted 12 May 2023 - 02:22 AM
A sketch (PFD) and a better description of the process will help to get a meaningful answer.
What level of accuracy do you need?
My experience with the latex process was to use Pulsafeeder pumps to manage the flow rates of monomers and other reactants. If you don't want to use flow meter you may be able to use load cells combined with PLC.
More details better answer.
Conceptual Sizing Of Adsorber ColumnStarted by Guest_JJvdM_* , 24 Oct 2019 |
Separator SizingStarted by Guest_HOTTEST_* , 12 Mar 2026 |
Psv Downstream Line SizingStarted by Guest_Abdessamed1961_* , 03 Mar 2026 |
