Can anyone please explain me the nozzle sizing procedure for the Three phase separators ? Inlet and outlet (both liquid and gas outlet) nozzle sizing methods.
Nozzle Sizing In Separators
Posted 30 May 2023 - 02:22 AM
Posted 30 May 2023 - 11:21 AM
Search this forum and you will find lots of information.
Posted 09 June 2023 - 04:14 AM
There are mechanical and process criteria to estimate the nozzle size, mechanical is reliability which allows higher momentum (RhoV2) however the process criteria is different which often takes into account the impact on expected separation e.g. feed nozzle size depend on what other internals are inside the vessel e.g. type of feed device, de-entrainment device etc.
Refer catalogues on vendor websites (Koch Glitsch or Sulzer) for criteria of nozzle momentum as a function of feed device type.
Conceptual Sizing Of Adsorber ColumnStarted by Guest_JJvdM_* , 24 Oct 2019 |
Separator SizingStarted by Guest_HOTTEST_* , 12 Mar 2026 |
Psv Downstream Line SizingStarted by Guest_Abdessamed1961_* , 03 Mar 2026 |
