Vacuum System Simulation In Aspen Plus
vacuum system ejectors liquid ring pumps condensers
12 replies to this topic
#1 panoska
panoska
  • 321 posts
Posted 03 June 2023 - 02:37 PM
Hello everyone,
I was trying to find an example how to simulate a vacuum system in Aspen Plus. But, I could not find an article online.
Could you please share your experience with me?
  • 6,988 posts
Posted 03 June 2023 - 08:07 PM
If you master atmospheric distillation, should be easy.
Try YouTube, you should find videos.
#3 panoska
panoska
  • 321 posts
Posted 04 June 2023 - 01:12 AM
I was not very precise. I am not interested in vacuum distillation. But, I am more interested in the vacuum system (ejectors, condensers, liquid ring pumps, etc.).
#4 breizh
  • 6,988 posts
Posted 04 June 2023 - 01:31 AM
I don't believe you will find anything in   Aspen plus regarding your query.
https://www.cheresou...-in-aspen-plus/
Try your favorite search engine for equipment design.
Note: Prepare specifications sheets and submit them to vendors/manufacturers.
#5 panoska
panoska
  • 321 posts
Posted 04 June 2023 - 05:01 AM
Thank you so much Breizh! I will go through your documents.
I was wondering why it us not possible we do the heat and mass balances around the vacuum systems ourselves? Like for a example with a refrigeration cycle?
#6 breizh
  • 6,988 posts
Posted 04 June 2023 - 06:11 AM
Ejectors are static mechanical devices, very specific equipment with performances very much linked to the design. As a Process guy you don't design it, you may be able to trouble shoot if you understand the physic associated with the Ejector.
In other words, let the specialist to take the risks, just provide the process data.
#7 panoska
panoska
  • 321 posts
Posted 04 June 2023 - 08:25 AM
Ok Breizh, thank you so much!!
I am curious to learn more and understand what make the ejectors more special than compressors!! ????
#8 breizh
  • 6,988 posts
Posted 04 June 2023 - 08:44 PM
Consider a steam ejector on process point of view to be a black box where you pull the non-condensable and may be some come condensable materials. You need to perform a mass balance around your system (column +condenser) to get the quantity of materials pull by the ejector (search info on this forum a lot already posted and/or visit Graham website). For the quantity of steam, you need input from the vendor, you just need to give him input about the pressure /temperature of steam available.
Note: If you pull some water out of the system, you may need a jacketed ejector to prevent ice built up at the throat of the ejector.
More homework is needed on your side and forget about the idea to simulate every piece of equipment.
#9 panoska
panoska
  • 321 posts
Posted 05 June 2023 - 10:00 AM
Thanks Breizh for the explanation!
I convinced myself to forget the simulation of the vacuum system hehehe ????
#10 shvet1
shvet1
  • 476 posts
Posted 06 June 2023 - 12:39 AM
https://www.graham-m...cuments-library
#11 Eduard Osipov
Eduard Osipov
  • 3 posts
Posted 04 October 2023 - 12:26 AM
I have some experience in modeling vacuum overhead system in Aspen HYSYS, Unisim Design and ChemCad. If interested, I can send links to my articles. I think a vacuum system could be included in Aspen HYSYS.
#12 panoska
panoska
  • 321 posts
Posted 05 October 2023 - 07:11 AM
Yes please send me some articles!
Thanks!
#13 Eduard Osipov
Eduard Osipov
  • 3 posts
Posted 18 October 2023 - 06:41 AM
Links to articles (free access):
https://www.mdpi.com...-9717/9/11/1865
https://www.mdpi.com...-9717/8/11/1333
https://iopscience.i...3/6/062006/meta
https://link.springe...891-019-02020-7
