Minimizing The Objective Function
minimize function constraints transportation
#1 chemtoli
chemtoli
  • 33 posts
Posted 06 June 2023 - 12:12 PM
If anyone of you could help me please why I can't get the same results as it is written at the bottom of the page
#2 MrShorty
MrShorty
  • 519 posts
Posted 06 June 2023 - 04:03 PM   Best Answer
I haven't spent a lot of time debugging, but I note that the solution found by Solver results in a value 13805 for the objective function in K11. If I copy the alleged solution into the decision variable matrix, K11 is 25863. As currently programmed, it appears that the alleged solution from the problem statement is not the minimum solution.
I haven't been through it all in great detail, but maybe that will suggest some places to look.
Edit: I looked a little closer and I see the problem. As currently programmed, you are saying that the cost for P1 to supply C2 is 0 (D3 is blank), which is very different from the problem statement that says that P1 cannot supply C2. Same for the other "-"/blanks in D3:E5. You need to change something so that Solver will not try to have P1 supply C2.
Edited by MrShorty, 06 June 2023 - 04:23 PM.
#3 chemtoli
chemtoli
  • 33 posts
Posted 06 June 2023 - 05:02 PM
MrShorty
thank you so much you are 100% right. Check this out 100% correct
thank you so much
Edited by chemtoli, 06 June 2023 - 05:08 PM.
#4 breizh
  • 6,929 posts
Posted 07 June 2023 - 02:17 AM
Thanks to share with us the references of the documents you are using.
To me this is the same problem you shared one week ago.
#5 chemtoli
chemtoli
  • 33 posts
Posted 07 June 2023 - 10:04 AM
Yes you are Right Breizh this is almost the same problem I couldn't understand until MrShorty explained to me.
