Oil Leakage From Breathers Of Floating Roof Tank
13 replies to this topic
#1 Zack1984
Zack1984
  • 8 posts
Posted 27 July 2023 - 10:20 PM
We observed oil leakage from breathers of floating roof tank having crude oil. Do anyone know the reason or root cause of this incident?
  • 6,939 posts
Posted 27 July 2023 - 10:55 PM
Please delete repetitive posts.
Is it a new problem? If yes, check for process change and or equipment defect.
#3 Zack1984
Zack1984
  • 8 posts
Posted 28 July 2023 - 05:42 AM
It occurred for sometime previously. But that was minor. Now leakage was huge. What process change? It's a floating roof tank which stores crude oil. Breathers are supposed bto breath out vapors not liquid. That's a thing to be think
#4 breizh
  • 6,939 posts
Posted 28 July 2023 - 06:03 AM
You may find pointers in the document attached.
Check the as built drawing of your ST.
#5 Bobby Strain
Posted 28 July 2023 - 12:58 PM
There must be a problem with the floating roof. Does the device only leak when filling the tank?
#6 Zack1984
Zack1984
  • 8 posts
Posted 28 July 2023 - 01:38 PM
Yes, we observed it during filling.
#7 Bobby Strain
Posted 28 July 2023 - 03:36 PM
The roof is not properly floating. It is "sticking" against the wall causing pressure to build under the roof. So, it needs to be inspected and repaired.
#8 Zack1984
Zack1984
  • 8 posts
Posted 28 July 2023 - 10:35 PM
If pressure is being built up, breathers should release this pressure. Breathers are designed to do this as vapors and gas. Why would Oil comes out of breathers?
#9 breizh
  • 6,939 posts
Posted 29 July 2023 - 03:11 AM
For process change, I was thinking new transfer pump with different head vs Flowrate.
Regarding equipment defect, do you have a preventive maintenance program in place for your storage tanks and associated equipment.
#10 Zack1984
Zack1984
  • 8 posts
Posted 29 July 2023 - 05:13 AM
Everything same for this tank. PM schedule is there. Only change was, this tank received Slop oil from Refinery units during startup.
#11 latexman
  • 1,893 posts
Posted 29 July 2023 - 09:01 AM
If the floating roof is stuck, rising liquid will eventually push all the vapors/gas out, but then, where will the liquid go as it continues to rise?  Out the breathers.
#12 Zack1984
Zack1984
  • 8 posts
Posted 29 July 2023 - 10:16 AM
Roof stuckness could be a major incident. Oil would have come out from many points, but unlikely, roof is moving normal. Oil leaks out only from breathers.
#13 Bobby Strain
Posted 29 July 2023 - 10:51 AM
So, do you have any other ideas?
#14 breizh
  • 6,939 posts
Posted 30 July 2023 - 12:02 AM
HI,
You may want to contact those guys:
https://www.ast-foru...sp?master=17920
Note: Do you have pictures to share with us?
