Cooling Tower
9 replies to this topic
#1 panoska
panoska
  • 321 posts
Posted 04 September 2023 - 04:38 AM
If we have to choose between two wet bulb temperatures 15 and 18oC. Then, 15oC can lead to a more efficient cooling tower.
#2 latexman
  • 1,922 posts
Posted 04 September 2023 - 05:51 AM
Let your cooling tower vendor select the design wet bulb temperature.
#3 panoska
panoska
  • 321 posts
Posted 04 September 2023 - 06:17 AM
If the vendor asks about it, then?
#4 breizh
  • 7,031 posts
Posted 04 September 2023 - 06:27 AM
You may want to perform some calculation based on statistic data from meteorological bureau (RH and ambient temperature).  I did once when I was working in Indonesia.
This may comfort you in your decision based on realistic data.
https://www.omnicalc...hysics/wet-bulb
#5 fallah
  • 5,026 posts
Posted 04 September 2023 - 07:11 AM
Wet bulb temperature is the lowest temperature a portion of air can acquire by evaporating only. Hence as the RH decreases, the wet bulb temperature becomes lower and vice versa...
Then it highly depends on the RH of the area where the cooling tower is being to install.
#6 latexman
  • 1,922 posts
Posted 04 September 2023 - 09:51 AM
I would look for a more knowledgeable vendor.  Marley has never asked me for this.  I am powerless to control the climate/weather; no one can.  The local historic weather/climate must be consulted.  A good cooling tower company will consult reliable resources for this data and have it ready to use.  Our scope is the process.
#7 panoska
panoska
  • 321 posts
Posted 04 September 2023 - 03:02 PM
Thank you all for your replies.
I am in the process of understanding the cooling tower process. It looks interesting and challenging.
Most probably, I will come with more questions.
#8 breizh
  • 7,031 posts
Posted 04 September 2023 - 05:17 PM
Consider the docs attached to support your study.
#9 panoska
panoska
  • 321 posts
Posted 05 September 2023 - 02:16 AM
Thank you so much Breizh.
#10 breizh
  • 7,031 posts
Posted 05 September 2023 - 03:28 AM
A few other resources.
