Washwater Injection To Hydrocarbon Stream At High Temperature And Pres
Posted 17 September 2023 - 02:13 PM
20000kg/hr Washwater is injected at location where pressure of the Liquid and vapor mixture of hydrocarbon stream is 45 kgf/cm2g and temperature is 220degC. (Approx mass flow rate of the HC stream is 250000kg/hr).
How to evaluate amount of washwater is in liquid and vapor phases?
For pure component system, it is quite simple to say based on saturation temperature and pressure of water.
Water is getting injected into a HC stream where partial pressure of water vapor in the stream is zero, so how will I know the percentage of wash water that will be in Vapor and liquid phase?
Kindly guide me.
Posted 17 September 2023 - 11:08 PM
You need a proper background. It is better to leave this issue to the professionals.
https://www.amazon.c...g/dp/0070116822
https://en.wikipedia...cess_simulators
https://www.google.c...nt=gws-wiz-serp
https://www.chemical...ference-library
Edited by shvet1, 17 September 2023 - 11:13 PM.
Posted 18 September 2023 - 02:27 AM
Would like to understand the process, how to approach such kind of calculations without simulators.
Thank you sir.
Edited by Venkat @89, 18 September 2023 - 02:28 AM.
Posted 20 September 2023 - 04:10 AM
This is not something that can easily be done by hand because you have a Liquid and Vapor mixture of hydrocarbon stream.
By injecting water the temperature of that mixture will drop (due to water vaporization) and consequently the hydrocarbon V/L equilibrium will change: you end up with less vapor and more liquid (due to some HC condensation). Also the specific heat of V and L change when temperature and composition change.
Edited by PingPong, 20 September 2023 - 04:11 AM.
Low-Temperature SeparatorStarted by Guest_guoyinyanliner_* , 15 Aug 2025 |
Missing Data For Stream ComponentsStarted by Guest_Desmith475_* , 07 Aug 2025 |
Negative Pressure Discharge / Negative At High PointStarted by Guest_felderosfelder101021_* , 05 Jul 2025 |
Pipe Fluid Temperature Increase Due To Solar LoadingStarted by Guest_HeemeshJ126_* , 06 Apr 2016 |
