Hydrocarbon Condensation When Relieved At Atmosphere
Posted 23 September 2023 - 06:08 PM
What are the issues in relieving a hydrocarbon (HC) to the atmosphere when this HC is relatively heavy and it is above its boiling point?
For example, consider 120 °C heptane stream being flared. Will the eventual unburned heptane condense and fall down to the ground when it enters in contact with 25 °C atmospheric air? Is it possible to occur a "rain of fire" in an extreme condition?
How could I simulate or calculate this event?
Thank you!
Posted 25 September 2023 - 11:50 PM
Flares have high destruction rate. I would suspect 98%. Experienced forummembers may correct me. This means that unburned portion of relief has low rate and pre-dispersed in large amount of hot air. Some HCs will be carried up by air, some - condense at mist which is not able to be settled down by gravity, some - vaporize and only small portion of this mist coalesce and form some sort of rain. Taking into account that area exposed is large rain can affect surrounding premises but this will rather not cause complaints as it will be in form of e.g. dots on a vehicle windshield.
This mist is able to condense and collect on surfaces if comes in contact with but usually this is not a case as surrounding structures are located far enough from plume.
Yes - such events (morning dots on windshield) are unpleasant, but who cares. This has a potential to reduce cost of surrounding premises but this is not the end of the world. Speaking of C6 all undistracted relief will vaporize and disperse.
Destruction is higher the less relief capacity. Taking in account that max relief has low probability such situations should be rare.
Usually combustion products (having low odor/toxic threshold) and smoke pose more problems that destruction rate.
If a flare has been designed (liquid separation, elevation, dispersion, radiation, destruction, sound decay, capacity etc.) and works well there is no chance of fire fallout or similar.
Hope the core ides is clear.
CCPS's Guidelines for Pressure Relief and Effluent Handling Systems 2nd ed.
6.5.6 Flares
Edited by shvet1, 26 September 2023 - 05:39 AM.
Condensation In Jackets And LimpetsStarted by Guest_Neha Vensiyani_* , 05 Apr 2024 |
How To Find K-Values Of A Hydrocarbon Mixture On Aspen Hysys?Started by Guest_Alexis Azamar_* , 08 Apr 2024 |
Hydrocarbon Dew Point Control UnitStarted by Guest_BabRafiq1_* , 05 Apr 2024 |
Pressure Drop Due To CondensationStarted by Guest_ATX_* , 01 Jan 2024 |
Subcooling And Vapor Refrigerant CondensationStarted by Guest_panoska_* , 19 Nov 2023 |
