Minimum Tower Diameter
17 replies to this topic
#1 AnbIran
AnbIran
  • 33 posts
Posted 17 November 2023 - 08:26 AM
HI every one,
I'm sizing a tower for a project. Estimated diameter is very low (550 mm) and flow path length is low in result of it (lower than 16 in).
So now Should I increase diameter (to around 750 mm) or it is normal to have towers with such low diameter?
#2 Bobby Strain
Posted 17 November 2023 - 09:57 AM
You should look at packing in lieu of trays.
#3 AnbIran
AnbIran
  • 33 posts
Posted 17 November 2023 - 10:39 AM
Yeah I thought about it but client wants tray tower
#4 Bobby Strain
Posted 17 November 2023 - 11:24 AM
Clients don't always know what is best. What is the service? How many trays? You can't service such a small diameter vessel.
#5 AnbIran
AnbIran
  • 33 posts
Posted 18 November 2023 - 02:59 AM
 It is a stabilizer in aromatic unit from pyrolysis gasoline hydrogenation, this column separates C5- from feed stream.
#6 Pilesar
  • 1,691 posts
Posted 18 November 2023 - 06:30 AM
There are specialist companies which supply column internals. Their engineers will give you definitive answers on what is possible and will recommend the feasible options. If you have a simulation, Koch-Glitsch or Sulzer or perhaps UOP should be able to give you a design. You will want expert advice to convince yourself and your client the best path forward.
#7 PingPong
PingPong
  • 1,477 posts
Posted 18 November 2023 - 06:49 AM
You could consider cartridge trays. The trays are connected to each other by tie rods and the whole section ("cartridge") is lowered into the small diameter column from above. To have enough trays multiple sections may be required and column will have to be multiple sections too with flanged connections.
https://www.google.c...iw=1112&bih=587
#8 breizh
  • 7,041 posts
Posted 18 November 2023 - 07:50 AM
Another great company to consult is Raschig.
Breizh.
#9 shvet1
shvet1
  • 476 posts
Posted 19 November 2023 - 10:44 PM
Estimation is based on what? Where did you get a recommended velocity?
#10 AnbIran
AnbIran
  • 33 posts
Posted 20 November 2023 - 04:31 AM
Thanks my friend, I hadn't heard about it.
Breizh.
Thanks bro for sharing documents.
I estimated it by KG Tower and Hysys
#11 Bobby Strain
Posted 20 November 2023 - 01:29 PM
What are you separating?
#12 shvet1
shvet1
  • 476 posts
Posted 20 November 2023 - 11:09 PM
As far as I remember KG-tower and Hysys calculate trays components. Why do you asking? Why do you consider 16'' is low?
Why is 550 mm low? I have been working with ID 400 mm at a chemical facility and have seen many such cases.
Describe in details your logic and actions taken.
Edited by shvet1, 21 November 2023 - 07:53 AM.
#13 breizh
  • 7,041 posts
Posted 21 November 2023 - 01:36 AM
To get an approximation of the diameter of the column with trays, consider this equation (extract from my old notes (>40 years)).
D =[4 *Mv/ (pi*Kv* (Rov/(Rol-Rov)) ^0.5)] ^0.5
D: diameter in meter
Mv: Mas flowrate vapor phase kg/h
Rol: density liquid phase kg/m3
Rov: density gas phase kg/m3
Kv: coefficient function superficial tension and distance between plate, cf attachment
distance between plates in centimeters
Superficial tension in dynes/cm
Hope this is helping you.
#14 thaihy
thaihy
  • 3 posts
Posted 01 December 2023 - 12:01 PM
FRI has issued the guideline for minimum column ID which relates to the size of packing.
#15 latexman
  • 1,924 posts
Posted 01 December 2023 - 12:34 PM
Can you attach the guideline, please?
#16 breizh
  • 7,041 posts
Posted 01 December 2023 - 06:50 PM
Attached another estimate for diameter sizing.
#17 katmar
katmar
  • 704 posts
Posted 03 December 2023 - 10:12 AM
My experience with cartridge trays has not been good.  It is difficult to get the tray sealed against the inside of the shell.  The most reliable method that I have found is to use sections with one or two trays per section plus a sandwich tray between the sections.  But all these flanges do add to the cost.
Speak to a specialist tray supplier to see what is the minimum diameter they can fabricate and then you can choose between the cost of making a column with a diameter larger than required versus the cost of a smaller column with many body flanges.
#18 AnbIran
AnbIran
  • 33 posts
Posted 16 February 2024 - 02:36 AM
Thank you for sharing your experience.
We are preparing suitable feed for reactors in an aromatics plant. actually, suitable feed starts from C6 naphthenic.
