P&id
p&id
#1 Quimarah
Quimarah
  • 21 posts
Posted 25 November 2023 - 10:45 AM
Hello everyone!
I'm working on a P&ID and i'm unsure on the approach i have to take.
Is there any bibliography that describes the selection of instruments.
I mean if it should be Discrete local, discrete primary front or back, Computer local, computer local front or back, logic local, pilot local, etc.
Thanks in advance
  • 7,001 posts
Posted 25 November 2023 - 07:08 PM
Let you Google PID instrument tags.
https://kimray.com/t...gas-pid-symbols
You will find plenty of information.
Note : as a Process Engineer working with operation team, you need to mention to your E&I Engineer what you want, this guy will update the P&ID accordingly. Let say on field (meaning local), on DCS/PLC, meaning control room. Most of the time data are continuous, meaning with trend on DCS/PLC. Important to indicate alarms with feedback to support the board operators and safety interlocks (safety matrix) with actions.
In other words, let you describe in words what you need (scope).
#3 Quimarah
Quimarah
  • 21 posts
Posted 26 November 2023 - 07:18 AM
Thank you for your help!
#4 shvet1
shvet1
  • 476 posts
Posted 26 November 2023 - 11:23 PM
Issues you have described refer to a local practice. You should combine local practices&requirements from opearting team, engineering team (process engineer + instrument engineer), management team (project manager, project consultant), and suppliers.
The same control principles may be solved opposite ways depending on local conditions.
E.g. I have encountered such option - a large distillation tower (~4x40m) had one level gauge on bottom and one hand-operated control valve on pump discharge to control liquid level in tower. An operator sits in a shed next to LG and does nothing other than 24/7/365 looking at LG and occasionally runing from LG to CV to open/close that. On the same application I have encountered 1 LG + 3 LT ESD + 1 LT DCS + Honneywell.
Good start for a newcomer is
https://a.co/d/gfTeiHv
https://bit.ly/46wX2YX
Edited by shvet1, 27 November 2023 - 12:07 AM.
#5 Quimarah
Quimarah
  • 21 posts
Posted 27 November 2023 - 06:57 AM
Thank you!
