Hello everyone,
Posted 27 November 2023 - 09:56 PM
Hello everyone,
Posted 27 November 2023 - 11:21 PM
I don't know where this "criterion" comes from
Safety, reliability, investment return. Which one are you interested in? Note that there are many criteria of velocity range: vibration, erosion, settling, stratification, etc. For example SimSci Pipephase uses erosion as per API 14E.
Start with safety, industry practice, money (chap. 5)
Edited by shvet1, 28 November 2023 - 12:14 AM.
Posted 28 November 2023 - 01:49 AM
I mean like this table (Link: https://www.google.c...AAAAAdAAAAABAD)
I do not know where this criteria comes from?
Posted 28 November 2023 - 02:16 AM
Hello everyone,
I am calculating pipe size for my project. One of the steps is to compare the velocity and dressure drop with the criterion, but I don't know where this "criterion" comes from? There are many tables on Internet but they do not mention a specific criterion (eg API, ASME,...).
If you know where this standard comes from, please let me know.Many thanks.
The project you are involved on should have Process Sizing Criteria including Line Sizing...hence you cannot refer to any taken criteria from internet with unknown source and basis...
Posted 28 November 2023 - 02:30 AM
Hello everyone,
Yes, I undestand that. I have researched how to line sizing on the internet, one step is to compare velocity and Pressure Drop with "criteria", but the source on the internet does not clearly where this standard comes from.
Posted 28 November 2023 - 03:01 AM
from investment return. See the link above.
Posted 28 November 2023 - 01:07 PM
There are many different sources that may give the recommended maximum velocity and pressure drop in piping depending on what industry you are in.
In the oil and gas industry API 14E provides recommended maximum velocity in pipelines based on errosion/corrosiobn considerations. For instance the maximum liquid velocity is limited to 15 ft/sec.
In gas flow the maximum velocity is typically limited to 60 ft/second based on noise generation above this velocity. I am not sure what code this comes from but it is a very accepted value.
These values can be further limited by other considerations. For instance in pumping systems the velocity is usually about 7 to 10 ft/sec on discharge. This is based on economics of the cost of pump versus the cost of the piping. For smaller piping it is less expensive but pressure drop goes up and so does pump horsepower size, cost of pump, and lifetime operational costs. For larger piping the pipe cost increase but pressure drop and pump size/power decreases and so does lifetime operational costs. It has been determined that best comprimise is at about 7 to 10 ft/sec on discharge piping. However on the suction side of pumps the limit is about 3 ft/sec based on minmizing pressure drop and providing smooth flow into the pumps suction.
When you do work for clients in oil and gas, refining and chemical plant industries they normally will have guidelines of what would be the maximum allowable velocities in the piping. Normally pressure drop per hundred feet of piping is sometimes used a criterion but instead of stating pressure drop/100 ft, limits in pressure drop is still stated as limits in velocities.
Edited by snickster, 28 November 2023 - 01:10 PM.
Posted 28 November 2023 - 01:21 PM
Here is link to Saudi Aramco Standard SAES-L-132 that provides guidance on velocity limits in piping.
Material Selection for Piping Systems | SAES-L-132 [PDF] PAKTECHPOINT
SAES-L-132 - Free Download PDF (kupdf.net)
Edited by snickster, 28 November 2023 - 01:26 PM.
Posted 22 January 2024 - 10:02 PM
Psv Downstream Line SizingStarted by Guest_Abdessamed1961_* , 03 Mar 2026 |
Surface Area Calculation For Blowdown Orifice Sizing Including FinnedStarted by Guest_victortheone_* , 17 Feb 2026 |
Steam Drum SizingStarted by Guest_nastaran_* , 01 Dec 2025 |
Sizing Of Condensate Return VesselsStarted by Guest_panoska_* , 23 Oct 2025 |
Horizontal Decanter Sizing CalculationStarted by Guest_peejoee_* , 07 Oct 2025 |
