Ratio Heat To Electrical
heat pump
10 replies to this topic
#1 panoska
panoska
  • 321 posts
Posted 02 December 2023 - 04:48 PM
Hello everyone,
I would like to share with you something that I was reading:
"The ratio of heat to electrical is approximately 3."
Have you ever see this factor 3? Where does this factor come from?
That is a way to convert thermal energy to electrical energy.
  • 6,887 posts
Posted 02 December 2023 - 11:37 PM
Order of magnitude is correct, with the link underneath, I got 2.24 for NG.
Consider this source to preform calculations:
https://www.eia.gov/....php?id=667&t=3
#3 panoska
panoska
  • 321 posts
Posted 03 December 2023 - 10:27 AM
Hi Breizh,
I used the same link for NG, but I calculated the ratio 3.7.
#4 Bobby Strain
Posted 03 December 2023 - 11:41 AM
I am confused. Please provide an equation, with units, to describe what you are referring to
#5 panoska
panoska
  • 321 posts
Posted 03 December 2023 - 01:48 PM
Actually, I used the material given by Breizh.
See the calculations below:
7.42 ft^3/kWh for natural gas-----> 0.21m^3/kWh_electr (eq.1)
The HHV for natural gas is 52,225 MJ/kg, which I converted to kWh/m^3 ----->
52,225 MJ/kg *(0,278/1/0,829) kWh*kg/m3------> 12,0358 kWh_heat/m3 (eq.2)
The ratio of heat/electrical can be calculated by multiplying eq. 1 with eq.2----->
ratio=0,21 m^3/kWh_electr. * 12,0358 kWh_heat/m3
ratio= 2,53 kWh_heat/kWh_electr.
(Ooopsy Breizh, I was wrong it is 2,53 the ratio eventually.)
#6 Bobby Strain
Posted 03 December 2023 - 03:24 PM
I don't know what you are trying to demonstrate. The conversion between heat in btu to KWHr is 1 KWHr = 3412.14 btu. Taken from Katmar's Uconeer.
#7 panoska
panoska
  • 321 posts
Posted 03 December 2023 - 06:04 PM
I try to calculate the ratio of heat/thermal energy to electrical energy!
#8 Bobby Strain
Posted 03 December 2023 - 07:32 PM
For what purpose?
#9 shvet1
shvet1
  • 476 posts
Posted 03 December 2023 - 11:44 PM
Good reference is also able being found in EU BAT
https://eippcb.jrc.e...pa.eu/reference
Similar docs are issued for US.
#10 panoska
panoska
  • 321 posts
Posted 04 December 2023 - 12:31 PM
I found a paper about heat pump distillation column, and they try to compare the electric power of the compressor with the reduction duty in the reboiler to compare it with the conventional distillation column.
#11 Bobby Strain
Posted 05 December 2023 - 12:13 PM
So, you can easily accomplish that without your equivalence. What matters is $. And capital cost. And other operating costs.
