I am trying to setup my dehumidifier ventialtion process in ChemCAD, and I'm not successful in getting the results I want.
I'm not exactly a student, but I am trying to learn ChemCAD.
I have a desiccant dehumidifier with a performance calculation from the OEM supplier, I am trying to copy and enter the calculated results in ChemCAD in order to design upstream and downstream systems.
To do this I am using a pre-cooler and a flash unitops. The problem with this solution is that I need to manipulate the cooler air temperature in order to control how much liquid output I get from the flash drum. Preferebaly I would like to keep the correct temperature and instead play with the efficiency of the flash drum until the liquid output reach the level that is shown in the OEM supplier calculations.
How can I do this? Or can you suggest an alternative method.
