Gas In Pipe Support
#1 Stellaandoor
Stellaandoor
Posted 26 January 2024 - 12:29 PM
Something confusing just happened. A carbon steel pipe used as a support only and not carrying hydrocarbon released sufficient quantity of gas, both methane and CO and triggered the gas detector while being cut for replacement. Where did the gas come from? Any similar experience? Any ideas?
#2 latexman
  • 1,894 posts
Posted 26 January 2024 - 01:06 PM
Your welder farted?!?
#3 breizh
  • 6,940 posts
Posted 27 January 2024 - 12:20 AM
Weird!
Is the sensor calibrated and in good condition?
Do you apply Hot work permit and monitoring prior to work?
Is it an original pipe support or recycling pipe used as a support?
Is it possible that the soil is polluted and contaminated the place or the pipe?
You are the only one to find out the root cause being at site.
#4 shvet1
shvet1
  • 476 posts
Posted 28 January 2024 - 11:02 PM
Moisture + anaerobic bacteria ingress. Typical for a confined non-vented space.
Note that stagnant water is able to produce an explosive atmosphere, e.g.:
- case 11.4.2.f https://a.co/d/6DIi72O
https://www.youtube....h?v=Y0tKDTVmwFQ
https://www.osha.gov...ons/hib19900305
Edited by shvet1, 29 January 2024 - 12:43 AM.
