Energy Loss In A Control Valve
steam energy
#1 andrade_mcg
andrade_mcg
Posted 02 February 2024 - 08:38 AM
Hi guys, I do have equipment operating at 2kgf/cm2 and because of that I need to reduce the pressure from 21kgf/cm2 to 2kgf/cm2 through a control valve.
2 questions:
1- This pressure reduction makes me lose energy
2- If this equipment was tested in a high pressure like 21kgf/cm2, if I operate it at 6kgf/cm2 the heat transfer is more or less efficient?
Consider 2 scenarios:
1- The equipment is a heat exchanger
2- I will heat water tthroughdirect steam injection.
  • 1,558 posts
Posted 02 February 2024 - 02:16 PM
Energy is lost when the pressure of a flowing fluid is reduced by passing through a control valve. Heat transfer efficiency is affected by many parameters. Pressure is not a primary heat transfer parameter in itself, but it can affect other important parameters like velocity, surface tension, density, heat capacity, latent heat of vaporization, etc.
#3 shvet1
shvet1
  • 476 posts
Posted 05 February 2024 - 12:37 AM
1 - Why do you concern about energy losses?
2 - Heat exchanger exchanges heat. Why do you believe it reduces pressure?
