Mass Balance Error
#1 Mohammad3799
Mohammad3799
  • 8 posts
Posted 19 February 2024 - 11:17 AM
Hi everyone,
How to solve a mass balance error in a rate based model for a regenerator column in HYSYS?
Thank you
#2 Fletch
Fletch
  • 45 posts
Posted 21 February 2024 - 09:12 AM
Check the threshold limits for flowrate parameters in any recycles, they will only push forward a fresh flowrate when there is sufficient difference between the values across the recycle.
Reduce the threshold and the recycle will keep the flowrate updated, reducing the discrepancy in your mass balance.
(composition error across the recycle could also influence the mass balance).
#3 Mohammad3799
Mohammad3799
  • 8 posts
Posted 03 March 2024 - 08:19 AM
thank you for your answer, I could finally solve the problem by playing with different parameters in the parameter tab. Especially changing the pressure drop calculation really worked.
